My app has updated to v5.92 (8217) and the issue persists. Samsung S9 / Android 10. Sending a test push notification from the PD web UI does NOT override volume on my phone.
This needs further investigation please.
@Inactive-Member-99077006 @AnthoP I can also confirm that setting the āRingtoneā volume slider to a non-zero value (i.e., āonā), and enabling the āDo not disturbā mode allows the Pagerduty app to sound an alarm if and only if āHigh-Urgency Override System Volumeā and āHigh-Urgency Override Do Not Disturbā are both enabled.
If āHigh-Urgency Override System Volumeā is not enabled, the app only displays a notification bubble and vibrates.
I keep my phone on āVibrateā mode (āRingtone offā) at all times. Sending a test push notification to the app does not override the volume settings to sound an alarm. This is causing me to miss high-urgency pages.
I also get this behaviour on 5.92 (8217) / Samsung Galaxy S8 / Android 9.
I successfully get a notification sound with
Do not Disturb: Enabled
Sound Mode: Sound
Only get a vibration with:
Do not Disturb: Disabled
Sound Mode: Vibrate
And receive no sound or vibration with:
Sound Mode: Mute
All this to say that Iām also experiencing that the āHigh-Urgency Override System Volumeā option does not override my Android sound mode/volume.
I think I may have figured this out. My pagerduty is installed in a work profile. So I had to install it in the my regular profile. (you dont need to set it up or anything on the personal profile.). Once I do that, I go to the work profile pagerduty and then I can enable high-urgency override which makes this all work.
Not sure how this could be fixed without fooling it like I did though.
I still have the problem with the app not overriding system volume in app version 5.92, Galaxy S8, DND off, volume silent.
A number of issues around DND are still being reported by Samsung users following the latest update to the app. Itās been raised internally; the plan is to resolve it as soon as is possible.
In the meantime, a workaround would be to download the contact card, add PagerDuty Outgoing Numbers to favourites, then rely on SMS and phone notifications.
Again, my apologies for the inconvenience.
Thanks
Hey there, also on 5.92 on Samsung S8 and still experiencing this. Just +1-ing
Thanks Chris!
We will update this thread as soon as we have more.
Apologies for the delay.
John
s10e, android 10, PagerDuty app 5.92 (8217): Still no sound when I test an alert with vibrate + override system volume
+1, I experience this on 5.92 on my OnePlus 7 Pro.
I have 5.93 (8282) on Android 10, and this has not fixed the issue. I have to have my sound on for the page to alert, which defeats the entire point of having a pager. I get woken up constantly at night by alerts for other things since I have to have my sound enabled. Since this is really the main functionality of this app, allowing people to get paged at all hours of the day and night, can we please get it prioritized urgently to be fixed?
I can pull logs, or do whatever is needed to help with this. I need to go back to sleeping again
Hey all,
Appreciate the concern over this one. The mobile team are discussing how they would fix this samsung specific issues but they are unable to specify yet when a fix for this would be released.
The work around being that they should download and update the PagerDuty Contact Card in the app, to favourite (or star) the contact, and to use an SMS/Phone notification rule for the time being.
We are very sorry for the concern this causes but we will do our best to keep you updated as things progress.
John
Hi all
Iām Chandler the Product Manager for mobile here at PagerDuty. I wanted to give you an update and thank you all for giving feedback and detailing the issue.
Weāve been working on fixing this issue for a while (seriously, Dylan on the Android team has had multiple phones ringing, and not ringing, all over his house for weeks). Unfortunately, there is a bug in the way Samsung has implemented Do Not Disturb scheduling and DND overrides on certain Samsung devices with certain versions of Android.
To add some more detail here, the overriding of DND works fine, but when we tell the Samsung phone to return to the userās DND schedule, it fails. In the end, it appears PagerDuty turned on DND and because the schedule is missing, DND stays on indefinitely.
We suggest the following workaround:
We are continuing to work on improving our notification settings and make things better for Samsung users. We appreciate that you reached out and reported how your app and phones are behaving so we could diagnose and work on finding solutions.
Chandler
Mobile at PagerDuty
Hi Chandler,
Thank you for the update. However, unless I am mistaken, it seems like most people are not having problems with DND but with the volume override. Last time I tested, DND override is actually working on my Samsung S8 phone, but the volume override isnāt. So I canāt leave my phone on silent or vibrate at night (like I normally do) because I will miss notifications. The workaround will also not work as I would need to leave the sound on to be able to hear the call.
I may be able to start actually using DND, but I am not sure how it will affect my other notifications/settings. Also, are you guys certain this is a Samsung bug? I donāt have actual data to back up my guess, but it seems like my PagerDuty worked fine until about a few versions ago. Like I said, I donāt know for a fact, but for me it seems like the app stopped working properly after a PagerDuty update and not a Samsung one.
As @petralfire mentioned above, this is beyond inconvenient. Is there anything we can do to help fix the issue, and make sure this gets addressed sooner than later?
Thank you
I also want to add I have an LG Thinq and this is an issue for me. So Iām not sure itās a Samsung specific issue. And to add to what fkarczeski said above, itās not a DND issue, itās an issue with PagerDuty not overriding the phoneās volume settings. It used to be your ringtone/alert could be silenced, and PagerDuty would override this to make the alert sound, setting the phoneās ringtone/alert to on instead of silenced. Youād then have to manually update this back to silence but that was fine, because I could have my phone on silent and still get pages. Now the phone volume isnāt overriden and the alert comes through silently.
Has anyone considered a rollback? This wasnāt an issue until a specific update, and yāall know when it started breaking, so could you rollback the notification code to fix this issue?
Same issue here with version 0.93 on an up to date Samsung Galaxy S8+.
I donāt enable DND at night, but even without it, as long as the Ringtone volume on the phone is set to vibrate, the notifications are also muted altogether. If the ringtone is set to any value, no matter how low, then the override will work as expected.
Unfortunately, the test notification functionality on the site is rate limited, which also isnāt helpful to troubleshoot this further.
Same issues for me with PagerDuty Version 5.93 on a Samsung Note9 running Android 10.
As has been said by others, this isnt a DnD issue but a volume override issue. With the override setting enabled in the PD app, permissions for override enabled on my galaxy s9, DnD disabled on my phone and my phones volume for notifications turned off all incoming alerts from PD do NOT override volume.
Itās not a DnD issue. Please continue working on this. Iām entering a second on-call rotation now and I have to keep my entire phone volume on/up at all times. Itās beyond inconvenient.
Hi again!
Weāre working hard on solutions (seriously Dylan apparently even thinks about this in his dreams) and itās a top priority. Unfortunately, Volume Override and DND Override features are super intertwined on devices. When we fixed the issue with DND overrides outlined above, then Volume Override doesnāt work properly for those Samsung devices.
Weāre working on a specific fix for the specific devices with this issue. Unfortunately, because the devices are responding to DND Overrides and Volume Overrides unexpectedly itās a bit of a tricky thing to do. We expect the next version of the app (should be available early next week) to improve things, and please reach out either way.
We appreciate your patience and help as we try to work around these device and OS limitations/issues. Itās a bit of a moving target - different Android versions and different devices implement Androidās volume APIs in different ways. Continue to let us know about issues youāre having, we really appreciate it.
As I mentioned before, a good workaround is to use a phone contact method paired with DND override for the PagerDuty contact.
Chandler
Mobile Product @ Pagerduty
While we have addressed issues with LG settings in the past, we donāt expect this issue with LG devices. Iāll let the team know youāre having problems with volume override on an LG Thinq.
Could you let us know what version of Android your device is running?
